-   -   Water in Head?? (https://www.racingjunk.com/forums/showthread.php?t=21564)
dynaguy03 08-06-2008 07:08 PM
Water in Head??
I dyno'd my motor last week. I have it in the garage with the bag over it. Tonight i removed a valve cover to install different valve cover gaskets and noticed small area's of clear looking water.. in a few low areas of the head. It doesnt look like a milkshake... is this just condensation or should i be worried.. the other head didnt look exactly the same. If the dyno was using just water would it look clear if there was some kind of leak??
thanks
Keith
zipper06 08-06-2008 09:18 PM
Could be condensation, where i live it's so humid if you cover a motor with plastic, the next day every thing is rusted, even in the summer, i've got 2 blks right now that i have to clean or revat, from storing them in my shop over the winter.
Do a pressure test on the cooling system, if there is no leakdown, it's probably condensation.
dynaguy03 08-07-2008 06:49 AM
water in head
I wish i could pressure test it... i havent installed it into the car yet since last weeks dyno session
Tod74 08-07-2008 08:23 AM
it does not need to be installed tp preasure test it. just hook the hoses to a radiator that don't leak sitting in the floor or fabricate a tube that will accept the cap/tester and loop the water pump to the thermostat housing.
Pull the drain plug and watch it drain...If there is water in the oil it will come out first
kwkracing 08-09-2008 06:04 PM
Does the engine have head studs or bolts?
dynaguy03 08-09-2008 06:26 PM
KW...
KW. i have heads studs no bolts...
kwkracing 08-10-2008 05:21 AM
are they leaking inside the heads? Maybe thats were this lil bit of water came from, i know they are bad about getting them to seal even when a good coat of sealer is applied. Just a thought. goodluck!
