Spark plug help/advice
I am in need of some advice on a suggested spark plug and heat range to go with. I rcently changed over from gasoline to alcohol in my blown 540 BBC. I have an Enderle bird catcher on it and looking to my fellow alcohol tuners on where to start on with spark plugs. What would you advise on running and I know it has to be a couple of heat ranges lower than race gas, just need a starting point.
Thanks, |
heat range for plugs
with NGK's, try heat range 9, should be close..
im running autolite 133 in my 468" blown alky
Running NGK 9's in s/blk 1471 on alcohol.
Zip. |
NGK 8s or 9s seems to work best out here. Don't go to cold on alcohol.
| All times are GMT -8. The time now is 07:44 PM. |
