8-3/4 dodge rearend?
i have a 8-3/4 dodge rearend,i was not allowed to run last night because i have no back brakes,so i'm wanting rear disc brakes and can't afford to buy new ones,so what model car or truck do i need to look for to fit this rearend,i have hurd 79-80 dodge but i don't know,does anyone know what i need to look for,any help will be appreciated,,,,thanks steve
mine came off a dart, but can be found on the duster, fury, they also
came with the dana, not sure if the brakes are universal, good luck :wink: |
:) :) If you need everything , get everything from backing plates, to drums, 8 3/4 has two bolt patterens, large and small, if you get everything then it will work with no problem. Mark
Re: 8-3/4 dodge rearend?
thanks guy's,still looking,,,,steve
i forgot to send some of the info that helped me on my first 8.75
good luck :wink: http://www.4secondsflat.com/rearendtech2.html |
thanks man
| All times are GMT -8. The time now is 08:18 PM. |
