-   -   TOURQE CONVERTER TO TIGHT (https://www.racingjunk.com/forums/showthread.php?t=21683)
TYSON3660 08-25-2008 06:52 AM
Last night we put motor in our car but when we put the trans in and thighten it up the torque converter would not turn. The last to motors we put together the converter would turn. How much play should be in there. We have a mid plate that is about 1/8 thick. Do we need a bigger mid plate?
johnracer 08-25-2008 11:03 AM
Make absolutely certain the converter is in all the way....
TYSON3660 08-25-2008 02:18 PM
it is
john910 08-25-2008 02:39 PM
on the three tabs that are on converter . do they have 1/8 in shims on them ? some have 1/4 to make up for mid plate.
kwkracing 08-25-2008 03:26 PM
if the convertor is for a aluminum mid plate, the converter is going to be 3/16" longer than a stock convertor. You should have roughly .100" of clerance out of the pump.If your converter is all the way in and is bound between the flywheel and front pump housing you have a few options.
Look at the pads where the convertor meets the flywheel and centers in the flywheel, they should have a 3/16 piece of steel welded on, cut them off.
Make sure the flywheel is on the engine correctly.
If its a powerglide, the input shaft may not be all the way back in the tranny, the wedding ring might be holding out a lil bit.
Lastly do some clearancing to the snout......Caution!!!
What kind of tranny is it and what has been changed on the combo?
