-   -   engine oil dip stick (https://www.racingjunk.com/forums/showthread.php?t=21711)
john910 08-27-2008 03:24 PM
trying to get a oil dip stick for a 85-96 chevy 350 that is on right side of motor. for a s-10. go to dealer and they need to know what the application is for. got a chrome one from a speed shop and it leaks. any help. thanks
johnracer 08-27-2008 04:03 PM
Any should work. I'd just tell them it's for a C1500 to keep it simple....
john910 08-27-2008 04:40 PM
dip stick
all tubes are two long . all i need is a tube 6-9 inch. long
lookingaround 08-27-2008 05:07 PM
put silicone around the chrome and put it back in.. :D
john910 08-27-2008 05:43 PM
tried that. chrome ones are to tight. tried to grind off some chrome with silicone now it leaks. would like to find one from general motors and try it.
cepx111 08-28-2008 12:54 AM
On my motor I had to put a o-ring on the shoulder of the dipstick tube where it goes into the pan and then silicon the hell out of it. Now its dry as a popcorn fart down there now.
Cp
us7race 08-28-2008 02:21 AM
Is it blowing the dipstick out? Or leaking where it goes in the block at the bottom?
john910 08-28-2008 03:05 AM
just leaking.
ARUSSELL 08-28-2008 07:23 AM
Pull out the dipstick and put a freezeplug in the hole. I have a site pulg in the side of my oil pan and with this setup no leaks!!!!!
john910 08-28-2008 08:42 AM
where do you get a freese plg that small? the hole is 27/64". thanks
