-   -   carb problems slow bringing up RPM on the trans brake (https://www.racingjunk.com/forums/showthread.php?t=21712)
zzadco 08-27-2008 07:37 PM
I have a 331 ci gm 3310 pound car 6200 stall powerglide with brake
6.20 gears 28x10.5 tires 1.57 60 foot and i cant get ET below 7.00
best et 7.19 96 mph I had a borrowed carb and had no problems bringin up RPM on th break , I now have a baker hp 750 now but it is slow bringing up RPM . any thoughts
us7race 08-28-2008 02:24 AM
Sounds like Converter to me... The carb as long as there is no dead spot should get there no problem..
hammertime 08-28-2008 05:06 AM
Re: carb problems slow bringing up RPM on the trans brake
I'd barrow the other carb again and see if it fixes the issue, could be a converter issue but if other carb fixes it, its a fuel issue.
zzadco 08-28-2008 06:33 PM
I changed car at the trac and I noticed it right away , this baker comes on real hard at half track my mph is higher with the baker it just sucks when i stage it takes about 5 sec to get to 6200 rpm on brake . same size jets the baker does have power valve , also has 50s pumps frunt and back with 32s sqirters front and back
dparker 08-28-2008 09:32 PM
Block off your powervalves and see what happens.
