15x10 8lug wheel fit on dana60 front
JUST WANTED TO KNOW IF 15X10 8 LUG WHEELS WOULD FIT ON A DANA 60 FRONT GM, IVE HEARD YES & NO DEPENDING ON THE CALIPER.THANKS
Depending on the backspacing they should fit, if not a small amount of light grinding on the caliper may be necessary. 15" rims fit better on a 60 than they will on a 44
yep steel wheels should fit, aluminum wheels are usually a little thicker and you might have to grind the caliper, but will also work.
| All times are GMT -8. The time now is 10:48 AM. |
