-   -   starter problems (https://www.racingjunk.com/forums/showthread.php?t=21807)
jjam 09-08-2008 05:27 PM
starter problems
My neighbor has a 67 Camaro he just put in a 383 motor. Now if he disconects the coil and turns over the car everything sounds good, but he hooks up the coil to start the car and the starter sounds like it is grinding or staying in guage. Bad sound, I guess I need to get under the car and see if the starter is staying in guage, has anyone ran into this problem? Help Thanks
us7race 09-08-2008 05:52 PM
What kind of starter? also need to check to see if it is staying engaged..
jjam 09-09-2008 12:53 PM
powermaster high torque mini, engage is what I'm thinking. But like I said I need to get under the car.
ARUSSELL 09-09-2008 01:10 PM
Make sure the timing is not too far advanced, that will over stress the starter.
jjam 09-13-2008 03:00 PM
found problem, I needed to install the shim to move the starter back. The gear was too close to flex plate. Like I said I just needed to get under the car, starts with no problems and he is happy. Things we do for our neighbor's. Thanks, for everyones help
