timing
bought an h.e.i. with advance built-in.do you still set timing as normal? my balancer is marked at 36-do you still bring that mark to zero? thanks
If 36 is what you want your total timing to be....then set it to where your 36 deg mark will be at TDC pointer when looking at it with a light. just make certain the advance is all in when you set it.
| All times are GMT -8. The time now is 10:29 PM. |
