-   -   external oil / vacuum pump (https://www.racingjunk.com/forums/showthread.php?t=21942)
superstreeter 09-28-2008 06:32 PM
looking at installing an external oil pump with vacuum pump, but I need to reverse the pump so it turns counter clockwise, no room to mount it to the back, I want to keep it a wet system, just like the idea of adjustable oil pressure and a vac pump all in one. and pros and cons out there ?
Tod74 09-28-2008 10:44 PM
I know a couple of guys using them and they love em.
ashbros 10-03-2008 12:39 AM
I had an alcohol injected 615 I used a star vacuum system and a wet sump oiling system with a 3 qt. accumulator. Couldn't be more pleased with the set up.
Provide an email address thru rj and I will send pic of my set up to you.
