Piston Rings
What brand rings would you run in a 582 BBC with a vac pump on alky. Also run low tensions or no ?
Total seal sells a blower/nitrous ring that's pretty good and can stand up to nitrous. But they are about $250.00
Zip. |
Re: Piston Rings
For n/a on alky I would go with a plasamoly top ring and a low tention oil ring.
I run Ackerly and Childs rings. I have run them for the last 5 years and have zero problems with them. I do run nitrous and alcohol but I know they make a ring for all applications.
http://www.akerlychilds.com/ |
| All times are GMT -8. The time now is 05:05 AM. |
