Braille batteries
Anybody use Braille batteries. I noticed they want you to use their charger which is only a 2amp charger. Not very good for charging between rounds at the track. I run two optima's, but could get by with only 1. I could run 2 Braille batteries and only weigh what 1 regular battery weighs!
Thanks |
The lightest battery on the market and nobody uses them?? Maybe I should stay away from 'em too!
Braille Batteries
The battery sounds good if you get a large enough one. Personally I think it is too expensive for most bracket racers. Each battery is around $250 for one recommended for a high compression engine. You have to make sure you get the one suited for your need. Here is a link to their website.
http://www.brailleauto.com/productca...?idCategory=16 |
| All times are GMT -8. The time now is 04:52 AM. |
