-   -   Cam, Springs and Torque Converter. What Should Buy?? (https://www.racingjunk.com/forums/showthread.php?t=22056)
MillerTime12 10-16-2008 11:54 AM
I have a 98 Camaro with a chevrolet 383 w/ a Holley Double Pumper Carb. , Flat Top pistons with 6 in. rods and a set of 291 Heads and a 373 rear-end. This is a drag car project. I will be racing a 1/4 mile with this car.
I need some suggestions on a Cam, and springs and a Torque Converter with a good stall to match since the transmission needs rebuilding anyway. I want the best proformance possible without wasting alot of money. We are on a low budget with this car. Give me your ideas.
Thanks for the help,
Dillon Miller
radicalz 11-12-2008 12:59 PM
Re: Cam, Springs and Torque Converter. What Should Buy??
Dillon Miller
:D :D Hey Dillon....first think about how fast you want to go then we can go from there 12's 11's....?
russ67chevelle 12-14-2008 10:17 AM
YOU BOUGHT CAM ALREADY?YOU SAID ON A DIFFRENT SECTION YOU SELECTED A 3800-7200 CAM?
IF I WAS YOU ID GO WITH EITHER COMP CAMS EXTREME LINE OR VODOO CAM BY LUNATI. YOU SAID YOUR ON A BUDGET THOSE ARE MY TOP 2!!!'
