Wiring up a Ford Solenoid / Wiring up 2 batteries
Hey guys, I am going to put a ford solenoid on my Camaro. It has a regular chevy starter on there now. If I remember correctly, you have to jumper something on the original starter. I just can't remember. Also I am looking for some diagram to help me wire up 2 batteries. I have the recharging post and the on/off switch that needs wiring as well. I had wired it up on my old Nova but can't remember for the life of me how I did it. I guess I am getting old :D . Thanks in advance for any help and/or advice.
Chris |
Solenoid
I put a piece of steel that I cut and drilled to fit between the starter battery terminal and the terminal that normally has the wire from the ignition switch. The cable from the starter terminal goes to one large terminal of the solenoid. The battery cable from the battery goes to the other side of the solenoid. The small wire that went to the Chevrolet solenoid goes the the Ford solenoid. The batteries need to be hooked up in parallel. The positive from one battery goes to the positive of the other battery. The same with the negative then you ground the negative cable to the frame. The positive cable then goes to one post of the battery switch and the other goes to Ford solenoid. Wire it into the system and you're set. Hope this helps.
Re: Solenoid
Chris |
Batteries
You would hook the positive posts of both batteries together and the negative posts of both batteries together. Then hook the negative post to the frame. The positive post is then hooked the the battery kill switch. Then the rest of your wiring is the same as it was, with the exception of the new solenoid.
Re: Batteries
Appreciate the help. Chris |
I have always wired 2 batteries this way
Frame to Neg battery 1 to Neg battery 2 Pos battery 2 to Pos battery 1 to starter or solenoid I read it somewhere that you want to pull the negative one way and positive the other way.that way you are using the whole battery load available ..Balances out the battery and makes them last longer |
Frame to Neg battery 1 to Neg battery 2 Pos battery 2 to Pos battery 1 to starter or solenoid I read it somewhere that you want to pull the negative one way and positive the other way.that way you are using the whole battery load available ..Balances out the battery and makes them last longer From what they tell me is that if you wire to two pos together the battery wire that goes to the starter will pull most of the load from that 1st battery.. :shock: :shock: I don't know if that is true but sure does sound good :mrgreen: |
| All times are GMT -8. The time now is 03:49 AM. |
