-   -   8 or 10 inch rim for 28/11.5 slick. (https://www.racingjunk.com/forums/showthread.php?t=22122)
baxxxter3 10-26-2008 06:28 AM
Hi i was just wondering if i should use a 8 or a 10 inch wide rim using a 28/11.5 slick? What is the advantages of both?
bjuice 10-26-2008 06:37 AM
the 10 inch wheel will give you a "wider footprint" this mean more tire will be acutally making contact with the ground...which is a very good thing.
always go with a wider wheel when you can...even the Outlaw 10.5 guy's who must use a 10 inch tire are putting them on 12 inch rims and flattening out the foot print.
in your case there would be No advantage i could think of by using the 8 inch rim...go to 12 inch wheel if it will fit under your car.
Brian
gearhead1011 10-26-2008 09:59 AM
If clearance is an issue you will want to use the narrower wheel to pull the sidewall bulge in. Other than that the wider wheel should be the better choice.
