-   -   HELP!..12 bolt ring and pinion (https://www.racingjunk.com/forums/showthread.php?t=22169)
dynaguy03 11-01-2008 04:50 PM
Ok... i just got back from a diappointing day at the track. I broke the ring gear teeth on my 12 bolt.. Car is 3100 s10 w/14.5 32's transbrake.
Question is... these 5:14's richmond street gears only have 21 passes on them. They where setup by someone who does this everyday so i dont think they where installed incorrectly.I used to drive this on the street.
Are the Pro gears much stronger? i prefer not to do this till after 100 pases or more.
thanks
mytmouz 11-01-2008 06:14 PM
Pro gears are actually softer ( heat treat) than the street gears. They will take the shock load better than the street, but they will wear quicker...
johnracer 11-05-2008 03:14 AM
Exactly. If you run pro gears on the street, they won't last long. In a drag car, properly set up, they'll last a LONG time. IMO you need pro gears.....
john858 11-05-2008 10:02 AM
put a good cover on the rear with bolts that go to the caps that will help more than anything
A1979Malibu 11-05-2008 04:29 PM
Put a pro gear in along with the good cover. I raced all season with the pro gear and the cover and had no problems. I would also use Red Line oil the the diff as well. It's cheaper to do it right the first time than it is to do it twice.
us7race 11-05-2008 06:21 PM
What power level? What ET's?
What trans?
sg1586 11-07-2008 02:34 PM
Re: HELP!..12 bolt ring and pinion
thanks
3100 lbs, 14.5 32s and a brake!!! You most defiantly need pro gears no matter how fast your going!!!!
dynaguy03 11-09-2008 02:44 PM
Pro Gears
Thanks everyone for your response's.. I have the 5:14 pro gears installed and maybe i can sneak 1 more time out.
Usrace.. this is an s10 .. its running 10.40's with a power glide and transbrake... the motor makes about 640hp...
These street gears where in the car when i bought the truck.. i was told they where pro gears but after i inspected them there where numbers etched in the ring and pinion which cross ref to a street gear.
Guess it could have been worse... sure beats a busted motor.
Once again thanks everyone!!
Keith
