-   -   what alt bracket will work? (https://www.racingjunk.com/forums/showthread.php?t=22170)
chevy67deuce 11-01-2008 07:45 PM
I have a bbc 540 that I will run a motorplate on.I am using a csr water pump.I also am running a 871 roots blower 1v set up,what bracket will work?Keep in mind the blower is a 1v the only belt will be for the alternater.
bjuice 11-01-2008 08:04 PM
U Should be able to find it here.
http://www.alangrovecomponents.com/Catalog.htm
also i see your New here...so let me help you out. When you make a post asking for advise etc...post it in one section..it will get answered quicker and not confuse anyone. we like to keep it all in one thread.
i cleaned up your two other post
thanks :D
Brian
promod45 11-02-2008 06:39 AM
bracket
i have done alot of cars like yours and i mount the alt on the frame and i put the slider arm on the block, so the alternator rotates towards the block when loose and tighten towards frame. Its nice down on frame as you can leave it there when you pull motor and its out of the way when you are working on car. As for the slider arm i use a chrysler one as they have alot of different styles and angles,, good luck
kwkracing 11-02-2008 05:42 PM
I like mounting the alt to the frame also!
