-   -   Alcohol plug gap (https://www.racingjunk.com/forums/showthread.php?t=22178)
tomsiman 11-04-2008 07:09 AM
Alcohol plug gap
What is the gap that you use for your alcohol n/a motor
If the gap moves what does that mean
thanks for your help
hammertime 11-04-2008 07:38 AM
Re: Alcohol plug gap
I use .035 gap
If your gap is moving, have you tried to index them ?
If they are closing up you may need to look into a different plug.
tomsiman 11-04-2008 07:55 AM
Thank you hammertime
Thank you hammertime, for your help. I will use that when I change the plugs.
Thanks again
hammertime 11-04-2008 08:09 AM
Re: Thank you hammertime
Thanks again
when you said they were moving did you mean the gap was closing after it runs awhile ?
manley 11-04-2008 06:19 PM
I set the gap .030-.035 and ya what he said about the gap moving, thats not good!
