RJ Member Survey Problems...
Anyone else having issues with the survey just sent out on RJ? In the sections where you mark important, somewhat important or not important it will only allow you to choose one of the answers and not allow you to use it under other questions. I would like to complete the survey but it makes it hard to give the necessary feedback when the survey does not work properly.
Yep it did it to me also.
Yep, I tried it too & had to settle for only two answers.
Survey
Survey SAYS???????????
FIX the SURVEY.............! later G 8) |
i just took it and could not get all the answers posted---FIX THE SURVEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LIVELY |
Yep, just took it samething. Fix the survey!!!
I tried it it doesn't work, PLEASE FIX IT!!!
same here,need to scrap this survey and have another that works.
| All times are GMT -8. The time now is 06:35 AM. |
