Missing sensors
I have a 2000 BBC 3500 4 dr.Chev.Truck thats missing the 2 sensors aft of the last muffler.I did take the VIN to chev & the drawing they provided me shows them to be there.Mine have plugs in them..I cant find any trace of a wiring harness--It gets 10 to 11 miles per gal at 55-with or without trailer??Thats what started me looking for the sensor problem..it gets the same milage with.without a trailer-Im to understand the front & rear sensors telle the computer wheather its rich or lean--Without them it retards the timing & increases the fuel?Any help provided will be greatly appreciated--
Re: Missing sensors
Originally Posted by wlpatterson
I have a 2000 BBC 3500 4 dr.Chev.Truck thats missing the 2 sensors aft of the last muffler.I did take the VIN to chev & the drawing they provided me shows them to be there.Mine have plugs in them..I cant find any trace of a wiring harness--It gets 10 to 11 miles per gal at 55-with or without trailer??Thats what started me looking for the sensor problem..it gets the same milage with.without a trailer-Im to understand the front & rear sensors tell the computer wheather its rich or lean--Without them it retards the timing & increases the fuel?Any help provided will be greatly appreciated--
I've got a similar problem with 1993, 3500 crewcab. it has a wire hanging down near the sensor, one sensor wire is plugged in, but there's no place to plug the other one in. It also gets 10 to 11 mpg but at 70 mph, gets about 7 with 28ft halmark loaded. If i pull my flat bed trailer with car on it the truck doesn't even know it's back there and get over 10mpg. BUTTT!! when the truck is first started the check engine light is off and it runs really good, but after a few miles driven the check engine light comes, and there is a noticeable difference in the performance on the bottom end, but no change in gas milage. No one around here has a plug in for the computer so i don't know what code it is.
Zip. |
I would think that anything w/a Cat. & ECU will have O2 sensor... many rigs have (2) O2 sensors.
Zip: I am no expert on this subject, but your dillema sounds like a crank-shaft sensor. Had a problem like once myself... My Stock 4wd chevy truck (w/a manual trans) gets 10 miles to the gallon... consistenly. It has 33" tires/373 gears & a small lift... 97,000mi always 10 miles to the gallon. |
Originally Posted by zipper06
I've got a similar problem with 1993, 3500 crewcab... .... No one around here has a plug in for the computer so i don't know what code it is.
Reading over the 1st post in this thread I noticed you stated it's "missing the 2 sensors aft of the last muffler". Usually the rear sensors are in the pipe right behind the converter not the muffler. You should look to see if it has any sensors behind the converter(s). If it does then it shouldn't need anything behind the muffler. |
sensors
Im sorry,I meant behind the converter
| All times are GMT -8. The time now is 09:16 AM. |
