piston to head clearance
on a steel rod big block chevy what is the minimum piston to head clearance?
We, JE, Reccomend min .040 between the piston and head
Curtis |
engine is 468 4.310 bore.
I think doorracer is right if you run a good forged piston you need atleast .005/.006 clearance and you have to consider the rock of the piston. JE's recommendation of .040 is a safe one with "0" deck ht., the last 468" i put together i used .039 Felpro gaskets and it has 2618 flattop forged pistons with .0065 clearance. I put that much clearance in the motor because the owner wanted to be able to spray a 250 shot of nitrous. It's a pump gas motor and runs 6.80's 1/8 mi. no spray in a 3700lb street car.
JMO Zip. |
| All times are GMT -8. The time now is 03:15 AM. |
