77 pontiac 400 engine
Hello, I'm trying to identify an old engine I pulled from a 77 Catalina. It's supposed to be a 400. The #'s on by the front water inlet are 406978.
Chip Tatroe Owner/Operator 57 Chevy Wheelstander Truly American Enterprises www.trulyamericanenterprises.us[/url][/code] |
are there any letters with that number?
There is a YA, which means auto trans.
The # by the dist. is 86133, and the date stamp is I77 = Sept 1977. |
I thought on Pontiac Motors on the passanger sie of the block they has the Cubic Inch cast into the block? Above where the fuel pump is on a SBC...
I done some quick research and here is a list of sites... I still did not find your numbers..so are you sure you are looking in the proper location for the numbers? http://www.teufert.net/identify/identify.htm http://www.pontiacstreetperformance....p/blockID.html http://www.yearone.com/updatedsingle...ontengid1.html http://www.pontiacpower.net/castnum01.html |
good work us7, i ran pontiac back in the day, that number shows up in nothing i have. will talk to some old pals that ran them also.
numbers are on the block passenger side of the timing cover,and at the distributor in the rear, they will say the block, if its not cast in the block on the bottom by the motor mounts
im guessing the numbers you have by the water neck are the intake manifold numbers type in pontiac block numbers and do a search its not hard there a re a few guys out there but look for those numbers, and head numbers,and intake numbers and we can find them out on here for fun www.pontiacpower.net here is a good page |
| All times are GMT -8. The time now is 01:16 PM. |
