-   -   roller lifters vs plain solid (https://www.racingjunk.com/forums/showthread.php?t=22237)
john910 11-12-2008 02:10 PM
what will produce more hp? sbc 350, 30 over. a roller cam or plain solid lifter cam?
jmarksdragster 11-12-2008 04:43 PM
Roller
bjuice 11-12-2008 04:57 PM
X2
triniemi 11-12-2008 10:23 PM
But which one will produce most hp / $ :D
zipper06 11-12-2008 11:38 PM
Right here my friend, any day of the week.
http://img32.picoodle.com/img/img32/...tm_8c3b514.jpg
Will run with any roller on the market for the money invested.
dparker 11-14-2008 01:25 PM
Theres as much increase from a solid to a roller as there is from a hydraulic to a solid lift cam. Its one of the best $$ per HP that you can spend. The reason it is, is because the quicker you can close the intake valve, the more hp youll make. On a solid lift cam, if your ramp speed where as quick as a roller your lifters would fly off the cam. Because you can't put the spring pressure on a solid to keep the lifter on the cam, that you can on a roller. If you did, you would have to much heat lifter to cam and lose a lobe. The roller allows you to have more ramp speed and more spring pressure for more Horsepower.
john910 11-14-2008 03:21 PM
cams
what i should have asked is a hydraulic flat tappit to a solid flat tappit cam? i have a comp cam 292 501 lift and was thinking of going to a solid cam. what are the pro and cons.besides adjusting valve lash?
bjuice 11-14-2008 04:18 PM
you always stand the chance of floating a valve with hydraulic lifters if your wanting to turn it up (high rpm) as a drag car.....i personally have floated them on the street ( back in the day)..
if you are going to be seeing more street use then strip then hydraulic roller hands down ( IMO)..If its gonna be drag only ..OR you plan on turning it up (rpm) then go the other way....
oh yeah..i got a solid flat tappet in a 406ci....about a 520 lift...very quick..lots of bottom end.
also remember if you go solid flat tappet you need to break in cam the old school way.......( imo)
curtisreed 11-15-2008 04:03 AM
There is no way with the parts available today that I would run anything but a roller in a high performance motor. Street or strip. No worries about oils, breakin, etc. Just my opinion.
Curtis
mopar1962 11-25-2008 10:45 AM
roller will produce most hp and will also give best idle quality, happy holidays
