Torque Converter Help!!!!!
Ive got my engine for my '89 camaro almost done, but i need some suggestions on what stall torque converter i need.
The engine is a 383 w/ 291 heads, and a cam with a range from 3800 to 7200, valve float at 7400. I want enough stall to get this BIG car leaving hard off the line with out over doing it and spinning too much. Im hoping i can use the stock 16 in. wheels and 3.73 rear end for a while before changing to a 4.56 gear later next year. Thanks for your suggestions, Dillon :D |
CONVERTER SHOULD MATCH CAM UNLESS VEHICLE CANT HOLD TIRES DOWN THEN LESS STALL SHOULD BE USED,SO WITH THAT BEING IM GUESSING OFF HAND YOUR IN 9" LAND,PROBABLY A DOZEN GOOD CONVERTER COMPANYS TO CHOOSE FROM.I WAS JUST AT COAN LAST WEEK THEY HAVE A LOT OF SALES GOING ON,,,
ESSENTIALLY FIND A CONVERTER THAT WILL LAUNCH CAR @ PEAK TORQUE OR SLIGTLY LESS.I CANT TAKE MUCH OF A GUESS WITHOUT KNOWING EXACT SPECS OF COMPLETE VEHICLE COMBO,BUT IM GUESSING A 4500 STALL MIGHT BE IN THE RIGHT BALL PARK... |
Saw your need for a converter. Keep one thing in mind. What ever you come up with in stall rpm's needed, add 500. I've never bought a converter and have it stall at advertized rpm's. They allways stall lower.
Dan |
| All times are GMT -8. The time now is 02:48 PM. |
