555 advice
I am planning on building a 555 this winter. Its going to be around 13.1 (unless I opt to go with the 14.5:1 pistons). I'll give the combo I have and then I have a couple of questions, hopefully I can get some input...
Dart 9.8 block 4.560 bore x 4.25 stroke SRP pistons 13.1:1 compression 6.385 rod Dart 325 Pro 1 heads, 2.30/1.88's, gasket matched only Victor 454r intake (4150) Prosystems 1000 cfm 4150 400 turbo trans 8" ptc converter (5500 behind 468, probably will have to adjust) 4.10 gear for now 28" slick Car weighed 3430 race ready and will add a little weight with the dart block. Here are my questions: 1. How much will the heads limit this combo? With my weight I would rather make power lower than higher, but I would think the engine should still support over 7000rpm's with the heads 2. What camshaft would you recommend to run with this combo 3. How much power potential and et's are possible? This is in a g body car btw.... Thanks |
Re: 555 advice
Dart 9.8 block 4.560 bore x 4.25 stroke SRP pistons 13.1:1 compression 6.385 rod Dart 325 Pro 1 heads, 2.30/1.88's, gasket matched only Victor 454r intake (4150) Prosystems 1000 cfm 4150 400 turbo trans 8" ptc converter (5500 behind 468, probably will have to adjust) 4.10 gear for now 28" slick Car weighed 3430 race ready and will add a little weight with the dart block. Here are my questions: 1. How much will the heads limit this combo? With my weight I would rather make power lower than higher, but I would think the engine should still support over 7000rpm's with the heads 2. What camshaft would you recommend to run with this combo 3. How much power potential and et's are possible? This is in a g body car btw.... Thanks 2. I'd call Bullet Cams for a cam if not just a Reher Morrsion Hot Rod Series Cam will be good. 3. Honest HP 875-915 max I'd use 14.5:1 compression and toss the 4150 stuff for a good 4500 carb and use a 4500 454R. |
Definately go with the compression. You will need a piston with at least 46cc dome to get that, but the power will be well worth it. I would also lean towards the Brodix 3xtra oval port heads if the budget allows it. A Brodix BM or Profiler Sniper manifold and a 1050 dominator will make more power than the 4150 series carb. I have all the parts in stock to do this combo at prices competitive to mail order. I also have a cam that will work, but you will have to call to get it. Can't give the numbers on here. Brad 864-578-5622 PAR Racing
Really for this year I don't have the budget. The short block and valve train is going to run all the budget I have for it this year. Maybe next year I can sell my 325's and 4150 stuff. How do you think this combo will run with the parts that I have? I'm sure the camshaft will be real important.
Hammertime I see you dealt with nyes, I talked to Pat the other day and I think I am going to order the shortblock from him. Was going to do it myself but I can't build it for that kind of money they sell for. Here is a pic of the car, still has bench seat, back seat, dot's, etc. http://memimage.cardomain.com/member...3_155_full.jpg |
Hammertime I see you dealt with nyes, I talked to Pat the other day and I think I am going to order the shortblock from him. Was going to do it myself but I can't build it for that kind of money they sell for. |
Guys Par is a premeier engine builder in the world. they have powered many world champions... |
| All times are GMT -8. The time now is 09:46 PM. |
