-   -   carb adjustment (https://www.racingjunk.com/forums/showthread.php?t=22381)
kimsbulldogs 11-29-2008 07:31 AM
carb adjustment
what is the best way to adjust two carbs on a blower motor?
bjuice 11-29-2008 10:23 AM
if they are not blower carbs to begin with you will need to send them off to BDS.Mert Littlfield or someone like that and have them blueprinted for a roots blower..
if they are blower carbs i would adjust like any other carb, which will include plug readings etc...
i personally prefer EGT Pyrometers for blower applications..due to the amount of air moved thru the blower...this is a sure fire way to see how lean or fat you are, without having to WOT ,killing it and checking plugs etc...
This is how i had all my blown motors set up ..alcohol and gas. inj and carb
Brian
kwkracing 11-29-2008 03:08 PM
need more info on your set up to help you!
