-   -   ENGINE SWAP (https://www.racingjunk.com/forums/showthread.php?t=22386)
koab26 11-29-2008 12:48 PM
ENGINE SWAP
I HAVE A 1962 FORD FALCON, WHAT WOULD I HAVE TO DO TO INSTALL A CHEVY V6 IN IT AND ARE THE ANY AFTERMARKET ENGINE SWAP PARTS FOR THIS OR DO I NEED TO FABRICATE THEM MYSELF. NEED A LITTLE HELP.
bjuice 11-29-2008 01:08 PM
don't really have an answer to your question. but i have to ask why go thru all that hassle just to drop in a v-6 :?: :roll:
many cheaper v-8's out here. you can buy a factory 260hp v-8 from the Chevy under $1500...at least for now you can before they go bankrupt. :D
radicalz 12-01-2008 04:02 PM
Re: ENGINE SWAP
Mmmmmm... a V-6......might want to upgrade like bjuice said small block v-8, turbo/blown small block v-8, BIG BLOCK CHEVY, etc, just think of the possibilities...... 8) 8) 8)
koab26 12-04-2008 06:40 PM
AFTER CONSULTING WITH MY ENGINE BUILDER HE TOTALLY AGREES WITH YOU GUYS. WILL I NEED TO CUT THE SHOCK TOWERS OR HAVE A CUSTOM CROSS MEMBER AND MOTOR MOUNTS. SOULD LIKE SOME FEED BACK. THANKS GUYS
