-   -   750 hp blower carbs on a non-blown engine (https://www.racingjunk.com/forums/showthread.php?t=22404)
SPEEDNEEDS1 11-30-2008 07:00 PM
I have 2 new 750 hp carbs that was purchaced for a blower application, sold the blower and still have the carbs. What do I need to do to run them as a pair on a 468. I think metering block has a vac. port on it to run to the blower for the power valve's. I plan to plug the power valve's. What else do I need to do?????
dparker 12-01-2008 10:38 AM
If you block the power valves you'll need to jet up 8 to 10 sizes.
Pwmax 12-26-2008 03:31 AM
The main difference is that the blower carbs, have boost referenced power valves. Just plug that off, and tune it like you would oterwise, and they should work well.
Frank
