Burn out question
66 Chevy II 14.5/32's, TH400 with trans brake.
How do you do your burn outs? Is a line lock the common item just for the burn out? My question is should I install a line lock/roll control to keep it in the box a little longer. How important is wheel speed in the burn out? Its a newbie question, but a complete review of the burn out would be very helpful. Thanks in advance. |
I am no expert, but I have been on the track a few times, this is what I do.
First a line lock will definately help with getting the proper heat in the tires. I have seen guys have the line lock and transbrake hooked in parrell. This helps in the staging lights to ensure the car does not move on the transbrake. Most of the time these guys do not need a line lock for a proper burn out, I am not one of them. I come to the water box, I rap the engine in gear in the box to get the tires good and wet, then pull forward out of the box about 2-3 feet. Depress the brakes fully, engage the line lock, rap the engine to 5000 in first gear and then run through the gears quickly. After about 3-5 second in high gear I let off the line lock and ride out the burnout. Let off the gas, place tranny in neutral, rap the engine good on the way to the staging lights, place in gear and hold on. :D I am sure there are alot of ways to do it, this is just the way I do it. |
Thanks Vader
Next question....I have a transbrake switch on my shifter. Where would you recommend the line lock switch go? Steering wheel? two switches on the shifter? |
I have a toggle switch on my shifter counsle, personal preference though. Down is off and up is on. When I am done with the burnout it is right there to turn off. I did have one on my shifter at one point, didn't like it much. Alot of guys will put it on the steering wheel, I personnally don't like the cord extending down the steering column. My recommendation is put it in a comfortable location for you. Just my .02
use the line lock to block the rear brakes from getting fluid from the master cylinder. This way you can have full brakes on the front and be able to feather the pedal out of the burnout and not skid the tires into the gaurdrail
you roll through water, when back tires are just out of waterbox engage brake, engage line loc, let brake off hit the gas good, get up on tire, get rpms up,shift to second, then to high gear and when they are ready let line loc button off as said above and come out |
i know, most people are so confused on how things work.
ssym don't ever feather the gas while doing a burnout. Your causing the stater in the converter to engage and disengage. It won't last long. I've never had to use a line lock.
My opinion would be to roll barely thru the water. Hit you gas hard and fast to about 3/4 throttle. Shift to high gear as quick as possible. As you feel the rear tires starting to bite go ahead and roll the gas to full throttle. Its very important to hit the rear tires hard otherwise your ass end will start to drift from side to side. |
we only use the front brakes to start the burnout, then release and let the blower and sticky tires do the rest.
IVE HEARD ON A TH400 BURNOUT TECHNIQUE IS BEST TO START OFF IN SECOND GEAR THEN GET INTO THIRD ASAP ON A ALL OUT TRANSBRAKE RACE TRANNY...CAN SOMEONE THAT HAS MORE INFO PLEASE SHARE???
| All times are GMT -8. The time now is 08:45 AM. |
