-   -   How much stall?? (https://www.racingjunk.com/forums/showthread.php?t=22416)
Drtmod5 12-01-2008 07:16 PM
How much stall??
Ok this is actually a few questions here goes;
My current setup is a 402 BBC in an '89 S-10 with a TH350 no brake 3500+ stall, truck weighs @ 2700lbs running a 9" with 4.56 gears on a set of 31" slicks. I'm getting things together to change trans setup to include a brake. My main question is this, if I put a glide in should I go with a different gear and also will I need more stall. I only run 1/8 mile where I'm from. Will I need to change alot of internal parts to stay together or will stock hold up? I've put in extra discs & clutches in the one I have sitting in my trailer but nothing more. I know I will change input to turbo. Any help appreciated. I'm on a budget here Thanks, Dave :x
us7race 12-03-2008 02:47 AM
Your 4.56 gears will work but I would say you would run faster with 4.88-5.38 gears depending on your HP and RPM range.
Is your stall made for a brake? If not is needs to be.
jmarksdragster 12-03-2008 10:03 AM
How much converter depends on where your engine makes power. What cam and RPM range do you run, and current ET?
Drtmod5 12-04-2008 02:09 AM
Cam specs are gross valve lift .612/.617, [email protected] 254/262, usually leave on footbrake @ 2000-2200 rpm shift at @6200-6500. Stock oval port heads, mildly ported, Team G single plane intake w/ alky carb. Current ET is low 6.80's/ low 1.4's 60' times. Also US7race, I have a set of 5.29 gears but they're not set up at this time. I'm not sure about the converter, I doubt it's designed for a brake. I have another that may work though. Thanks, Dave
jmarksdragster 12-04-2008 01:41 PM
A 9" around 4500-5000 would work best, stick with a 4.56 if you plan any 1/4 mile trips.
dparker 12-06-2008 05:29 AM
Re: Need some info
My current setup is a 402 BBC in an '89 S-10 with a TH350 no brake 3500+ stall, truck weighs @ 2400lbs running a 9" with 4.56 gears on a set of 31" slicks. I'm getting things together to change trans setup to include a brake. My main question is this, if I put a glide in should I go with a different gear and also will I need more stall. I only run 1/8 mile where I'm from. Will I need to change alot of internal parts to stay together or will stock hold up? I've put in extra discs & clutches in the one I have sitting in my trailer but nothing more. I know I will change input to turbo. Any help appreciated. I'm on a budget here Thanks, Dave
If the go to a powerglide the stock parts that you don't have to replace for your application are the plants, the case, the sirvo, and the front pump, the other internal part should be upgraded.
jmarksdragster 12-06-2008 01:50 PM
You need a high gear hub, input shaft, 5-6 high clutches, and a dual ring servo piston. Only use the 1.76 if using a factory gear set.
Drtmod5 12-06-2008 11:45 PM
Another dumb ? Is there a simple way of telling if I have 1.76 or 1.82? I may just wind up sticking with current setup. Starting to get discouraged with it anyway.
dparker 12-07-2008 07:37 AM
The 1.76 gear is alot bigger. Lets see, on the 1.76 gear the gears you see will come to the edge of the base on the plantetary and the 1.82 will be about an inch from the edge.
Instead of upgrading your stock powerglide you might try buying a used powerglide thats already setup. You should be able to get one, not tricked out, but that would work in your 402, from $700 to $1000 ready to go.
us7race 12-07-2008 08:04 AM
Here is a Pic...
http://www.putfile.com/pic/5999073#
