-   -   T&D or Jesel (https://www.racingjunk.com/forums/showthread.php?t=22447)
michael1 12-07-2008 10:28 AM
T&D or Jesel
Can anyone tell me the pros and cons on these rockers? I have the Big Duke 18* heads and need rockers.If there are any distributors of these companies please let me know if you can help me with pricing.Thanks
hammertime 12-07-2008 10:51 AM
Not sure on the dukes but a buddy just priced them for his BMF heads, TD was 400 cheaper then Jesels.
I've seen both break and seen both work well. I've ran Jesela and had good luck so I stay with them, if I bought a motor with TD i'd keep them and I am sure they'd work fine.
BEAST477 12-07-2008 12:03 PM
The T&D's i just got have oiling ports for the springs as well as the roller tips. Not sure about the Jesels. Just a thought.
lanham 12-07-2008 03:18 PM
I have the T&D sportsman rockers and like them really well.
obsessedtruck 12-07-2008 03:43 PM
T@D is a better deal for the Dukes. I have Jesel on mine and I'd rather have T@Ds. The adjusment is a much better deal (bigger). Seems the T@D holds the lash better. We found that out on my bosses blower motors. Hes got both types.
PAR 12-07-2008 07:35 PM
We use T-D exclusively on all of our engines from 565 bracket engines to 800" nitrous engines. I will have to order them for the 18 degree heads, as we use mainly Brodix 16 degree heads. I can sell them for about 1550.00. T-D will ship in about a week or 2. Call me at 864-578-5622 Brad
zipper06 12-08-2008 08:31 PM
I can see why PAR uses T&D over Jessel, i bought a set of T&D pros from a fellow racer here on RJ and they are nice. But before that i tried to get imfo from Jessel as to what offset i needed for the bodix 10 RPSP S/BLK heads that i had, all they did was give me a run around and wouldn't/couldn't tell me which setup i needed for these heads. The RJ person i bought the rockers from sent them to me to check out, it turned out i needed .250 offset which these were. I then called T&D about the setup and how to get started since my heads were already together and i could use their fixture. The tech spend atleast 15 min. explaining how to get there and sent me 2 sets of shims .030 and .060 to make sure that i was able get the right geometry and keep the roller oil holes lined up. I'll definately buy T&D in the future just from their customer service.
michael1 12-08-2008 09:25 PM
I heard the same thing,T&D has great customer service. That is the same thing I heard about Patrick at Pro Systems carbs. I'm all about customer service because I enjoy working on my own stuff when possible. I had back surgery so doing what I can on my own is like mental therapy to me.I need another surgery but I'm trying to put it off as long as I can.I want to thank everybody for the info.
vmnelson 12-29-2008 01:27 PM
DITTO ON THAT!!!! We do our best to use their produts just for this reason, well plus it's a good product!!
us7race 12-29-2008 06:30 PM
My Jesel Rockers have treated me very well. They hold lash great too.
No experience with T&D.
