Looking for good Machine shop in Ohio....
I am looking for good reputable Machine Shop with decent prices around Columbus Ohio, maybe Akron/Canton area. I am in Newcomerstown, Ohio, just south of New Philadelphia.
I just got a used crank that spun a bearing and needs welded and turned and checked to make sure it's not twisted. I will soon need a block bored, splayed caps intalled and line bored/honed. Building a 406 and/or 383 stroker. Thanks, Travis P.S. Also curious if any of them would be hiring :D I would love to build engines for a living :D |
Re: Looking for good Machine shop in Ohio....
I just got a used crank that spun a bearing and needs welded and turned and checked to make sure it's not twisted. I will soon need a block bored, splayed caps intalled and line bored/honed. Building a 406 and/or 383 stroker. Thanks, Travis P.S. Also curious if any of them would be hiring :D I would love to build engines for a living :D Since the theh Dart SHP block has came out we hardly do all that work to an 010 type block, By the time a guy buys a block strips it, sonic test, clean and mag, cut the block for splayed caps drill and tap, line bore and line hone, deck, bore and plate hone your talking 1200 to 1500 dollars. On other thing a few months ago we bought 6 blocks and only 2 were good enough for a high performance build because of thin cylinders and don't go by core shift as thats a bad indicator. An SHP block all machined to your door is 1795.00 just something to think about. Here is a link on those blocks. http://speedtalk.com/forum/viewtopic.php?t=12112 |
Carl,
Thats a really good deal on those. That includes shipping also? You must get a really good price on them? Are you a full WD? Frank |
Originally Posted by Pwmax
Carl,
Thats a really good deal on those. That includes shipping also? You must get a really good price on them? Are you a full WD? Frank So far they are a good seller and we just got 4 more in to find out Dart does not line hone there cam tunnels or main lines any more just on these blocks!! |
| All times are GMT -8. The time now is 05:27 AM. |
