-   -   377 SBC Help?? (https://www.racingjunk.com/forums/showthread.php?t=22461)
dparker 12-10-2008 12:10 PM
377 SBC Help??
Can you get any bearings for a 377, 400 block and 350 crank, where you don't have to use bearing spacers. Bearing spacers don't look like a good setup to me. I haven't dealt any with a 377, is it a good engine setup? Pros and Cons...
hink 12-10-2008 01:51 PM
This block would cure all your problems
http://speedtalk.com/forum/viewtopic.php?t=12112
us7race 12-10-2008 02:31 PM
Have to us the spacers.. A friend of mine has them in his Vega.
377 stock 2 bolt block on alky runs 6.40-6.50 with a GM forged crank.
Has ran this setup for more than 5 years. :)
fla1976 12-10-2008 05:42 PM
377
Ran a 377 for a couple years. Never a problem with the spacers. Still have them out in the garage somewhere. Used a forged GM crankshaft.
prostreet1972 12-10-2008 06:53 PM
He left the 2 bolt alone...he didn't turn into 4 bolt splayed??
I am thinking about building a 406 on a very tight budget and was curious if 2 bolt would hold up to 13:1 comp. and occasionally a 150 shot.
zipper06 12-10-2008 08:29 PM
My Teriatory,
Get over it the spacers work just fine, i ran them 25 yrs ago and i run them today. The engine in my Malibu is a 377" and it's been 8,000 rpms. I also run 14 to 1 compression on alcohol. Actually the spacers are a plus they have 360 degree grooves and i drill an extra 1/8" oil hole at 45 degrees in the main bearing for extra oiling. I run a main girdle and it's 2 bolt block. In fact after i assembled the block and installed it in a dragster for the first run, we discovered a leak in the blk. We put 13 passes on the engine and it ran 5.16 1/8 and 8.23 @ 158 qtr. mi at Memphis. We broke out at Super Chevy with 5.14, we ran no water in the dragster. I then pulled the engine out of the dragster and found a 4" crack just below the deck of the blk. I welded it up with a tig/ hammering after each 1/2 weld with Ni-rod, didn't even pull the heads off. I then installed it in my Malibu and have close to 100 passes running 125mph, 10.50's qtr. and 6.52 in the 1/8 and the car weighs 3250 lbs.
I'm pulling the motor out this winter to install a 434", but the 377" is still ready to go.
JMO and experience
us7race 12-11-2008 02:19 AM
Yes. It does have studs and I am sure he had it line honed to make sure the saddles were straight. He don't spray it though. Just a bracket car.
Here is a Pic..
http://i133.photobucket.com/albums/q...e/DSC_3469.jpg
flight71 12-14-2008 09:36 AM
Dont be afraid of the spacer bearings, i run them in my .060 over 377 shifting at 8200 with 2 stages of NOS it was splayed but never had a bearing problem even with the 650 shot of spray, even bent all the rods in it once still with no bearing issues!
