chevy 4 speed info
have two 4 speeds complete 6261886 and two empty cases 3851325 and 39225661 need info so i can sell them? thanks
Transmission
The 6261886 is a Saginaw.
the others are muncie casting numbers and the trans should be alum.
Muncies
Ed,
The "325" case is 65 or older with a 7/8 cluster pin, I believe the "661" is 70-72 Muncie with a 1" pin. Email me if you want to sell the 661 case- I build Muncies on the side. Scorp |
| All times are GMT -8. The time now is 01:34 AM. |
