anyone had exp. w/covenant cargo trailers????
metro trailer sales based in alabama advertises 8.5 x 24 enclosed trailers on rj for 3990.00 if you pick them up at the plant in grorgia,has anyone bought one (or know someone who has)?? looks like a pretty good deal for a new trailer,but i'd like to talk to someone who's had experience with them. thx.
Trailers
It has to be 2-3500 axles and the trailer weighs around 3500#, that ony leaves you about 3000# or so. Buy one with the 2-5000# its worth the extra money. Make sure the framing in the floor and walls is 16" on center. I live in FL and bought one in Melbourne on Wickem RD. It is an Extreme Hauler made in Prentice , Miss. Payed $5150 out the door, that tax,tag,etc. Has escape door on side and RV style door up front. First thing I did was change all the tiedowns and use grade 8 bolts. Then removed all the int plywood and insulated with foil back foam, sides and roof. 100% improvement. Fill all the cracks in the floor next to the wall, it will suck dirt and water inside. Only use it 1-2 times a month pulls good at 70-75. Bought it in June of 08. I looked at used crap that I would not pull let alone put my car in and they wanted $2500-3500. Even a certin dealer in Lakeland had over priced used crap. When you buy at the low end they are all about the same just do your homework.
Any ? let me know, TIM |
trailers
Oh it has the aluminum mags and the bigger tires too, 2int lights, stone guards it looks good for $5150.00. It was by far the best deal for the money.
trailer
Look at add #1405113. Mine looks like this with 2-5000# axles, int lights, alum. mags, pt floor,escape door.
| All times are GMT -8. The time now is 05:41 AM. |
