-   -   need help ??? (https://www.racingjunk.com/forums/showthread.php?t=22703)
roger61670 01-04-2009 07:58 PM
need help ???
I have a 2001 MONTE CARLO SS , and the check engine light is on . The code read's there is a malfuntion in secondary air ! Nobody around here can tell me what this is . PLEASE I need some advise and help . THANKS Roger :?:
ztlonewolf 01-04-2009 08:45 PM
http://chevroletforum.com/m_15983/tm.htm
this sounds like the same problem your having,may be water in your secondary air pump,or a blown fuse,if you look on down the page in the link,there's a post that tells you what to look for,hope this helps
shawnp 01-05-2009 02:30 AM
I had a 2000 ZR2 S10 with the 4.3L in it. Same thing happened. The air pump was in a area that would draw in water and cause problems in the pump. Had it replaced and GM even made a kit to put on to help solve the problem. It did not help. fter the 3rd pump, I put a peice of black tape over the check engine light.
