-   -   motor overheats..please help (https://www.racingjunk.com/forums/showthread.php?t=22720)
rechek5 01-06-2009 05:37 PM
i run a street stock class on a small small 1/4 mile so were not going very fast which means not much airflow
motor is pretty much a stock chevy 305 i run a hei dist. and a 2bbl rochester carb
radiator is a 3 core gm radiator
i have tried both electric and manual fan with shrouds..
i cant run a whole feature event without the motor getting so hot it pushes most if not all the water out of the radiator... please help
fla1976 01-06-2009 06:14 PM
Overheating
Check to make sure your radiator cap is good. If it is weak or leaking it will cause the water to boil at a lower temperature.
lookingaround 01-06-2009 07:17 PM
what about a thermostat or restrictors in the thermostat housing to slow the circulation so it can cool it
itsabird 01-07-2009 02:48 AM
try back filling the engine, makeing sure there is no air in the system, and if you are not useing it now, try water weter, good luck.
TopspeedLowet 01-07-2009 03:02 AM
Have you concidered that the cam timing is too advanced. This is a common problem with many stock chevys using towing cams. The other likely player would be a EGR that never shuts off. Sometimes the EGR gets hooked up to a vaccume source that keeps it active under full power. That will cook the intake and cause the engine to run lean. Then are you possibly running real lean?
Food for thought..........
rechek5 01-07-2009 05:50 PM
have tried water weter
have tried a thermostat and reducer
plugs actully looked a little on the rich side
and cam is a comp 260h and degreed to what comp wants it at
cepx111 01-07-2009 11:58 PM
Like above mentioned I'd try a new 15 to 16 psi cap first -thats a cheap fix.
Other thoughts....
I'd go with a bigger raditor if the rules allow, you might also consider a aluminum one if you can spare the change, they really make a difference.
Also a aluminum high flow water pump will make a big difference too - they can be had for around 50 bucks just about anywhere, I got mine from a vendor on here.
Goodluck, Charles
kwkracing 01-08-2009 09:39 AM
either the water pump isnt pumping, maybe the shaft broke off, maybe its full of rust or the thermostats stuck.
demo1976 01-08-2009 04:21 PM
i dont have any ideas for you to try but i also run a 305 with a 260h comp 2bbl and hei.. our motors are almost twins.. lol
