-   -   BBC Electric Water Pumps (https://www.racingjunk.com/forums/showthread.php?t=22757)
jreiley 01-11-2009 07:45 AM
I see lots of ads for electric water pumps. Any suggestions on the one to buy for a bbc drag car?
TopspeedLowet 01-11-2009 07:54 AM
I have had a few different brands and the Meziere pump I have has been in service for over 4 years and flows like a belt driven pump. The finish and quality is obvious when you have one in your hand. They come apart rather easily for any servicing you might need without any trade tools.
slowmotion 01-11-2009 07:57 AM
I have the shogun remote pump. Works good but better have an extra impeller just in case.
ashtrak 01-11-2009 08:08 AM
Which ever one you choose i would go with a high flow piece. IMO
hammertime 01-11-2009 08:10 AM
CSR for me
TopspeedLowet 01-11-2009 08:15 AM
Alot of guys jump over that fact. The high flow pump will back up pressure in the block and heads behind your restrictor and raise the boiling point further to eliminate hot spots in the head.
tcarda 01-11-2009 03:13 PM
I have used a CSR for 3 seasons without any problems.
jreiley 01-13-2009 10:02 AM
Thanks for the help.....
russ67chevelle 01-14-2009 04:55 PM
i have a mezere,but i see jegs has a line of them too
