-   -   Which carb to use??? (https://www.racingjunk.com/forums/showthread.php?t=22768)
BEAST477 01-12-2009 11:06 AM
OK guys what i have is a 540 chevy with BB2x heads,Brodix intake,cam 772 int. 765 ex. dur@ 50 285 int. 296 ex., 12.6 comp. It's going in a '65 Nova 2850 lbs turbo 400, 5600 stall, 4.56 gears. I already have a Ken Jones 1050 that worked fine on my 477 or do i need more for this setup?
dparker 01-12-2009 11:40 AM
I think your on the border of going to a 1150 from your 1050. I really think your combo will work well with either. I would keep the carb you have, you might gain a couple of .01s with the 1150 but I think the 1050 will be more consistant.
hammertime 01-12-2009 04:08 PM
1050 Should work fine with some adjusting :D
jmarksdragster 01-12-2009 04:53 PM
Frankly I like a bigger carb, but then I ran a 1250 on a 447 SB2, plan to run it on my 461. If your 1050 runs well you won't find a lot of difference, I saw about 20 HP on the dyno between the 1050 and 1250. I wouldn't waste my money on an 1150. You won't see enough difference to be worth it. Unless you plan to put a pair of them on.... :shock:
BEAST477 01-12-2009 05:20 PM
Thanks guys, i was planning on the 1050 since i already had it but i just wanted some input. Thanks again.
hammertime 03-24-2009 07:35 PM
If you plan to be @ 131 the first few weekends to test I have a 1150 APD gas carb you can bolt on and try. :D
BEAST477 03-26-2009 04:37 PM
Yeah David, i plan on being there on the 4th and the 11th unless it's snowing. I shouldn't say that too loud should i. Thanks for the offer i've also got a 1250 i can try if needed.
bjuice 03-28-2009 05:36 PM
Use that 1050 Beast....PAR uses a 1050 on his bracket series 565ci and gets 1020hp out of them..
check out the link.....
http://www.parraceengines.com/engines/565.htm
TopspeedLowet 03-29-2009 03:36 AM
Cold weather in michigan
Originally Posted by BEAST477
Yeah David, unless it's snowing. I shouldn't say that too loud should i.
Please do not say snow out loud Mike. I still have not had a good enough day (or time on a good day) to fire up my 582. It is sleeting out right now, my timing light is hooked up and she is full of water. Just needs C 15 and decent weather and a minor pre lube. Michigan weather sucks at this time of year. Out track opens April 5 for testing, weather permitting.
Bruce
hammertime 03-29-2009 06:14 AM
this weather sucks !!! going to finish the nitrous on mine today and adjust a few things, start it up again to make sure all is good and put it in the trailer :D
