stang rear set up
chevy guy building a 90 mustang drag car 10-11 sec car
w/adj uppers, plates ,etc.wheres a good place to start for best traction? 2deg dn? 0? antiroll any help?9in tire.8.8 430:1 |
I set my Mustang up with 2-3 degrees pinion angle and no preload on the anit-roll with the suspension loaded. What other suspension do you have.. shocks, struts, coil-overs??
lakewood coil overs up front,strait lowers/adj uppers w/factory springs
for now but it does have upper coil over/anti-roll installed for future use aje-or similar k-frame w/mid-front plate & pg tubular x-member and yes its tied in w 14pt cage & factory sheetmetal thanks for the input! |
| All times are GMT -8. The time now is 08:23 PM. |
