Cloyes hex adjust
Has anybody had any or heard of any problems with the top gear not staying tight due to a heat treating problem?
I use Hex-a-just on every engine i have build for the last 10 yrs. that doesn't have a belt drive and the only probem i've had was the excentic bushing cracked on one big block setup. The tech at Cloyes told me they had batch of bushings that were heat treated bad, and sent me 2 replacements, overnite USPS no charge. The only thing he ask me too do was email him a pic of the cracked bushing to show the mechine shop forman. I emailed the pic. on wensday about 3:00pm, got the new ones in thursdays mail. I have replaced chains after a couple hundred runs, Jegs. stocks them.
I do use the small O.D. lock washers on the allen head screws that fit in the machined out c'bored slots, so i haven't had any come loose that i know of. Zip. |
Re: Cloyes hex adjust
Yeah David thats what i heard too so i was just checking. I've heard of no others except the same situation you're talking about. Seems strange :? .
Thanks Zip makes me feel better. Thanks Mike |
Like I said he may be right but I've also ran them for years without any trouble and actually know a few who purchased new ones last year and ran them without issue. I think the install might of been wrong on them but couldnt know for sure, lost count how many motors broke all with the same issue :wink:
I never used the hex adj but the other one they make is a better design in my opinion...adjusts like a belt drive with slotted holes.
| All times are GMT -8. The time now is 06:51 AM. |
