-   -   i need some help (https://www.racingjunk.com/forums/showthread.php?t=22878)
mrtopdogg 01-24-2009 08:38 PM
i need some help
im currently building my first small block its a 350 bored 40 over im trying to build a 357 block fresh from machine shop all arp main bolts an head studs 4valve release flattops my heads are rhs 220 20.2 /1.60 64cc i know their big but i got them on sale. have 2 intakes a rpm air gap an a tm-1, 750 holley i have a 350 turbo with shif kit 373 posi rear will change gears if itll help in a monte carlo i need tips an suggestions on a cam an stall that will work with what i got will be used for street an strip
JEFF69Z28 01-25-2009 03:25 AM
YOU IN THE RIGHT PLACE FOR ADVICE.IM DOING THE SAMETHING(406 CID) I'VE BEEN IMFORMED TO USE 4.30 TO 4.56 GEARS AND 4500-5000 STALL TO GET IT OUT OF THE HOLE.I BOUGHT AFR 210 HEADS AND THEY HAD COMP CAMS GRIND ME A CAM TO MATCH MT SET UP.CALL COMP CAMS AND THEY WILL BE ABLE TO HELP YOU WITH A CAM AND ATI FOR A CONVERTER.
mrtopdogg 01-31-2009 09:30 PM
how about this cam an stall
bracket master2 300/ 300 , intake 515 exhuast 515 stall 2800-3200
