Tranny cooler
I am running a turbo 400 tranny and it dosent have a cooler should i get one or not? just wondering what my options are
Yes definitly get a cooler. If you're racing and going rounds you'll want to keep temps consistant to be able to keep your ET's consistant.JMO
a trans guage is also a good idea
Without a cooler I'd say your cutting the life of a race tranny by a 1/3. Especially if your running a stall converter.
Cooler
The cooler you can keep the tranny, the longer it'll live and will be more consistent. A gauge is a wise investment, especially with a brake and high stall converter.
I have always heard a 20° temp drop doubles the life of the trans.
Yep, trans cooler... CHEAP INSURANCE.
Always. Synthetic fluid will also drop it 10-15˚.
one thing about synthetic,,,,, does it change any characteristics in the trans,,,shifting ,,trans brake response ???
Not usually unless you are using a cheap thin fluid before changing to synthetic. It should also perform more consistently.
| All times are GMT -8. The time now is 03:23 AM. |
