-   -   H20 GAUGE (https://www.racingjunk.com/forums/showthread.php?t=22902)
JEFF69Z28 01-27-2009 07:12 AM
H20 GAUGE
WHERE IS THE BEST PLACE TO PUT THE SENDING UNIT FOR A MECH.WATER TEMP.GAUGE
Scooterz 01-27-2009 10:43 AM
There are a few locations. I usually use the intake manifold location ( I have Team G, towards the front) on my mechanical guage. Having said this, I am not sure if it makes a difference if sensor is located somwhere else.
promod45 01-27-2009 03:36 PM
sensor
i always put them in the head beacuse your heat is in the heads and you will see your temp sooner and after you shut your motor off you will see your head temp,, good luck
