-   -   stud girdles (https://www.racingjunk.com/forums/showthread.php?t=22933)
JEFF69Z28 01-29-2009 01:53 AM
stud girdles
How important are they and can i gain any horsepower by using them?
signsbyesa 01-29-2009 04:15 AM
i have never seen it but under high hspwr the valve train flexes and
the stud girdle keeps them in place under pressure, keeps the push
rods from going out of whack, there might be more but this is what
i was told back when i first started racing, good luck :wink:
http://www.catpep.com/catproducts/ro...studgirdle.asp
suicidebomb 01-29-2009 06:42 AM
I've also heard that by the time you buy studs,girdles, rockers, pushrods, and guideplates, you could almost buy a good shaft set-up. I don't know but that's what i been told.
JEFF69Z28 01-29-2009 06:48 AM
WHERE WOULD ONE SEE THE VIDEO
zipper06 01-29-2009 09:54 AM
I think if you're running over 200lbs of seat pressure on the springs you definately need to run a gurdle. I don't know if the valve train flexs without one but it definately ties the studs together and helps prevent the studs from breaking or flexing as much.
fla1976 01-29-2009 12:50 PM
Girdle
The stud girdle does all the above and it also acts as an extra lock for your adjusters. A little extra insurance.
srwilson8074 02-18-2009 08:57 AM
stud gurdles.
Would this apply to roller rockers as well? I want to make sure that my motor has everything that it needs to ensure long life. Any help or info is appreciated. :P
zipper06 02-18-2009 09:17 AM
I think most of us guy's run them even with a flat tappet cam motor with 140# seat pressure. I know i do it's just added insurance to the rockers backing off and the studs moving around.
Tod74 02-18-2009 12:13 PM
I've seen tons of old BBC aluminum heads that have actually busted a big chunk out of the head surounding the stud boss too....When I had a set of the old 074's on mine I wouldn't even turn it over without the girdle on it after the valves were set the first time.
IF you were starting with nothing, as in no girdle,rocker arms, guide plates, studs etc then you will have almost as much in the whole mess as a you would a set of sportsman series Jesels or T&D shaft rockers.. but if you already have good rockers and guide plates etc then that's different story.
dparker 02-19-2009 05:44 AM
Sunset Racecraft racing engines does not run them and has great luck. Last year at Indy it was said that 75% of the sportsman class had Sunset Racecraft engines. There reasoning is that when you put a stud girdle on it pulls some of the rocker studs to where some are in a bind causing them to fatigue and later brake. Its is true you have a extra lock, but you also have to loosen an extra thing to adjust. But on the contrary, Reher Morrison builds a great engine and uses stud girdles. I believe there reasoning is that it takes the harmonics out of the valve trane that causes fatigue. I have one of each and both are great engines. I've not had to readjust either.
