-   -   BBC Block Heaters (https://www.racingjunk.com/forums/showthread.php?t=23028)
degnitz_3732 02-05-2009 09:13 AM
BBC Block Heaters
Looking to put two "freeze plug heaters" in my BBC this winter. There only $27 in Jegs, and it says that one heater on each side will warm the water temp to 110 degrees.
Has anyone had experience with these heaters? You just plug them into a 110V cord I believe. Do they really work? Any problems with them?
Thanks,
Derek
hammertime 02-05-2009 09:24 AM
They work well and a good investment for them very cold days. sometimes it takes a hour or so to get warm though. But will keep the heat up between rounds.
superstreeter 02-05-2009 06:58 PM
Ya,,lol,,up north here,,,ALL the vehicles have them,,,usually just one.. it heats the whole engine. plug in for 3 hours at minus 50 and your ready to go. lol,,, no shit !!!
TheRabbit 02-06-2009 11:18 AM
The main thing to heat up is the oil. You can buy a simple heating pad from Summit. Install an oil heater when you freshen your motor. Running your car just enough to get water temp up is not long enough to get oil temp up. Even in the summer I use mine an hour or so before ever race and I live in the South.
