-   -   electric radiator fan (https://www.racingjunk.com/forums/showthread.php?t=23034)
bigmack 02-05-2009 07:57 PM
which is the best was to mount the electric fan front or rear of the radiator pushing or pulling, on a door car. :?
sds10racer 02-05-2009 08:41 PM
pulling thru. you get more area of the radiator exposed to air coming thru the shroud. mine was a pusher and didn't cool as good as when i switched to the other side of the rad.
cepx111 02-05-2009 09:03 PM
X2, PULLING IS THE BEST WAY.
bigmack 02-06-2009 06:49 AM
i have a couple of guys i know telling me pushing it is better.
ashtrak 02-06-2009 08:13 AM
X3 Pulling
zipper06 02-06-2009 08:18 AM
All you have to do is look at the automobile manufacturers who have electric fans comming out of the factory. all of them to my knowledge has the fans on the inside sucking with shrouds. I have a 19yr old corvette and it's that way. i'm sure that their engineers tested this both ways and used a proven method.
kwkracing 02-06-2009 09:04 AM
when you push air threw the radiator this is what happens... At slow speeds the cfm of the fan is pushing threw the radiator, as you increase speed the fan act like a solid 14" circle which is resistance that builds infront of the radiator, now air is going around the fan, not threw it. so now this terbulance is making most of the air deflect and go around the whole radiator inlet.
TheRabbit 02-06-2009 11:11 AM
Trust me pulling works better. I don't have enough space so I have to mount mine in front and it doesn't work as good. Also use a good shroud that covers as much of the radiator as possible.
