More funny....
Subject: A JOKE WITHOUT BAD WORDS
It is hard to find a joke without a dirty word or two in it. Here is one with none: Two tall trees, a birch and a beech, are growing in the woods. A small tree begins to grow between them, and the beech says to the birch, "Is that a son of a beech or a son of a birch?" The birch says he cannot tell. Just then a woodpecker lands on the sapling. The birch says, "Woodpecker, you are a tree expert. Can you tell if that is a son of a beech or a son of a birch?" The woodpecker takes a taste of the small tree. He replies, "It is neither a son of a beech nor a son of a birch. It is, however, the best piece of ash I have ever put my pecker in." |
UPS..... Just in case you need a laugh: Remember it takes a college degree to fly a plane, but only a high school diploma to fix one. after every flight, UPS pilots fill out a form, called a "gripe sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems; document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS Pilots (marked with a P) and the Solutions recorded (marked with an S) by maintenance engineers. P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit S: Something tightened in cockpit P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right. P: Number 3 engine missing. S: Engine found on right wing after brief search. P: Aircraft handles funny. (I love this one!) S: Aircraft warned to: straighten up, fly right, and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. And the best one for last P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget. :D :D :D :D |
I work for a company called Ram Aircraft so I have seen this before but it is still funny. (I don't work on the planes though, I run the engines on a dyno)
thanks dd i really needed to laugh this morning and boy did i.
loved the first one , sent it to some friends :D :D :D
| All times are GMT -8. The time now is 01:37 PM. |
