-   -   question on 350 transbrake (https://www.racingjunk.com/forums/showthread.php?t=23135)
fxbus2 02-15-2009 10:04 AM
Can you do a 350 transbrake with out having to get a special valve body?
I know 2 of the valves need filed down, and the case needs to be flat plus you need a solenoid to activate brake. Plus a few other mods, need to be done.Would be going in 71 chevelle with 13 to 1, 383 stroker motor 4.11 gears and 4200 stall converter. Thanks.
