Enderle cover
Does anyone know if Enderle makes a plate (or where to get one) for the timing cover to put where the fuel pump mounts? Mine is polished and looks nice (never mind pulling balancer and sealing everything back up) but, I want to change to a belt drive for the pump.
Thanks for any help |
Plate
If they Dont?
I surely could whip you 1 up Fairly Resonable? Let me know? Later Greg 8) |
bbchevy,
could you make it in polished billet aluminum? What could we do about a cam button of some kind? any ideas? |
Cover
It would be Alu.
As for the POLISH,thats up to You......? I could be Made to the Depth of the Inner side of the Cover,then Shim the Button Accordingly! Later Greg 8) |
OK, let me study on this a little bit.
The thing is I still have the hex drive on the cam! I am not sure about a cam button with that still on there. Of course if I have to take it off, I will just put on a new cover. I did find out Enderle does not make one. (Maybe for that reason) Any suggestions? |
can you post a pic of what you hex drive looks like, it should have a bearing around it that limits cam end play to the cover?
Yea, I forgot about the torrington bearing on it until I pulled the pump off.
I guess it would be the same as shimming to the pump extension. Thanks kwkracing! bbchevy do you have a cover to go by? |
cover
I Have an Original WEIAND BBC Cover hanging here on the Wall.
Later G 8) |
I don't know if the covers are the same or not. Is it notched on the bottom of pump mount for the balancer? because the plate needs to be.
let me see what I can find out. Took the pump and extension off and I see that the hex drive is almost flush with the outer cover. If my straight edge is right I have .016 between them, so we can just go flat with it. I'm sorry, I should have pulled that off before I started asking questions! :oops: I'll see if I can find a pic of the weiand cover somewhere |
Cover
N0 PR0BLEM!
Just Hope that i can Help? These Guys on Here have been a GREAT Help to Me,so maybe i can do the same? Later G 8) |
| All times are GMT -8. The time now is 01:54 PM. |
